USA verzija
USA verzija
Odgovor Napisal/-a busa » 01 Mar 2012, 21:53
ena dokaj zanimiva predelava, seveda ne gre brez ameriškega pretiravanja... :)
za osnovo je Z-CARSova predelava z honda motorjem.
link: http://www.audioprofiles.com/mini/ZcarsMini/index.htm
pa še tehnični podatki:
ENGINE DETAILS:
Engine as stock: A-Series Displacement: 998cc Power: 60bhp
With current modifications:
Compression: 11.0:1 Power: 495hp/353tq Redline: 8500rpm
ECU: 2002 RSX ECU with Kpro Tuning: Shawn Church (Church Automotive)
Heads: Stock Intake Manifold: Stock Polished
Fuel System: Aeromotive A1000 pump
Filters: Aeromotive 12301 & 12304 (one before pump, one after)
Fuel Regulator: A1000EFI
Lines: Russel Classic with return line
Fittings: Earls
Injectors: Power Enterprises 750mm
Fuel Rail: BDL
Throttle Body: BDL
Vacuum Block: BDL
Cooling System: Custom Zcars
Mounts: Innovative Engine mounts
Exhaust: Custom fabricated by Fabworx in full titanium
Ignition System: Stock Acura
Fuel tank: Custom made Fuel Safe powder coated red
FORCED INDUCTION SYSTEM:
Header: Custom fabricated titanium by Fabworx
Turbo: Borg Warner Model: S362 .70AR
BOV: Tial 50mm
Waste gate: Dual Tial 44mm
Intercooler: Custom
Piping: Custom fabricated by Fabworx
Boost Control: Kpro 4BAR Hondata map sensor
Boost Level: 18psi
NOS: Custom direct port nitrous system designed by Joe McCarthey/Prototype Racing
TRANSMISSION:
Gearbox: Stock Acura EP3 6 speed
Differential: Quaife LSD
Drive shafts: Custom by Zcars UK
Clutch: Competition Clutch Stage 5 Sprung
Flywheel: Stock
Shifter: Custom fabricated and made by Zcars UK
SUSPENSION
Springs/Shocks: Fully adjustable rebound and height by Zcars UK
Sway bars: Zcars UK
Bushings: Zcars UK
Race Jacks: KSport
BRAKES:
Calipers: Custom blue Wilwood 4 pot Powerlites front and rear
Brake Line: Exact UK
Disks: Wilwood drilled and slotted 260mm front and rear
Master Cylinders: Wilwood full race pedal set with cabin adjustable bias.
Brake Bias: Wilwood
WHEELS AND TIRES:
Wheels: 13” custom 3 piece made by Image Wheels UK
Tires: Yokohama A032R 215/50/13
Custom wrapped in carbon and matching powder coated centers
Re: USA verzija
Odgovor Napisal/-a gregor.tm » 01 Mar 2012, 22:14
ta, ta pa je stilsko čisto po ameriško! :? :? :?
škoda tako dobrih kosov na taki spaki ;)
Re: USA verzija
Odgovor Napisal/-a Miha » 20 Apr 2012, 14:42
gregor.tm napisal/-a:ta, ta pa je stilsko čisto po ameriško! :? :? :?
Zanimiva informacija o ameriškem okusu, ki prodira v Evropo. Na letošnjem sejmu v Essnu se to potrjuje. Sicer se pa v celoti strinjam z Gregorjem. Nekateri smo za klasiko, tudi če je narejena na novo.
